Related Items Extended No working before comment section
  • Posted by Thorstan Osborne (7) Offline
It seems to display related item, but only at the very top or very bottom of the page, if I choose any other position such as after content - it doesn't show.
So I can only display in position [top] or [copyright] but I would like it to display after article and before comment section, any ideas?
11 years 8 months ago #1 by Thorstan Osborne
also it seems positions [aside right] and [aside left] display
but nothing working for directly under article content...
11 years 8 months ago #2 by Thorstan Osborne
Hi thorst,
I have entered your website and temporarily enable the Preview Module Position to see the available module positions of your template, and I found that indeed your template doesn't have any module position after the content / before the comment. Please see this www.dropbox.com/s/gjdsvc39iwq77ai/seg.mp4?dl=0
11 years 8 months ago #3 by TemplatePlazza
I see, how is a position added there?
11 years 8 months ago #4 by Thorstan Osborne
You need to edit the index.php of your template file then add code like this :
<jdoc:include type="modules" name="positionname" />
after the section where the content is called.
Alternatively, you can embed the module via article by using simple {loadposition} and {loadmodule} tags. You can read how to do it here eddify.me/posts/using-the-joomla-load-module-plugin.html
11 years 8 months ago #5 by TemplatePlazza
Thanks! :)
11 years 8 months ago #6 by Thorstan Osborne
