Frozen website - Responsive Slider Banner
- Posted by Diego (2) Offline
I am using Responsive Slider Banner on my website but after 30 seconds the website freezes. Responsive Slider Banner uninstall and website works normally.
www.ipbf.edu.ec/ipbf/
Best regards, Diego
11 years 8 months ago #1
by Diego
Best regards, Diego
Hi I have opened your website and unable to see the problem you mentioned. The banner goes well even after 30 seconds.
11 years 8 months ago #2
Additional move the mouse over the 3 blue buttons (right menu) and after a few seconds the website freezes.
11 years 8 months ago #3
by Diego
Hi diego, I think I know what caused the problem. You are using javascript mouseover effect on the buttons while the slider using the same mouseover script to make the slider stop sliding when mouse over the slide. So sometimes when you're hovering your mouse over the buttons, it intereferes the slides to stop the autoslide.
Btw, is there any reason why you're using old javascript method to get a hover effect for those buttons? Why don't just simply use css for it? I think using the css button will fix the problem.
11 years 8 months ago #4
