Plugin like module
- Posted by BalZycia (7) Offline
At first thank you so much for amaizing Related Items Extended Module.
Please let me know Are you thinkig about create plugin exactly like this module.
Module is nice and powerfull but I have to use another plugin to add modul into article.
I need something more userfriendly - do you know what I meen.
11 years 8 months ago #1
by BalZycia
Hi BalZycia, Glad you like it
Module has a 'flexible position' benefit that make it easy to display the module content in any position you wanted on the template. You can place it anywhere you want (for example left/right sidebar, after comment, top etc ). So, if you want to make the module displayed after your article then you can publish it in a module position after the 'content' section of your template, isn't it?
11 years 8 months ago #2
Yes You have right but I need different solution.
In this way module display under coments, adsens and any other plugin. I need to display it under content, abouve coment and advers.
BalZycia
11 years 8 months ago #3
by BalZycia
BalZycia
Hi, we'll consider it. At the moment you can use {loadposition} or {loadmodule} tag inside your article content.
11 years 8 months ago #4
Yes I know that. But I need solution when I add module once for all.
or plugin which display related article on the same way like your module
11 years 8 months ago #5
by BalZycia
