cut word
- Posted by Fouli (3) Offline
Hello, thanks for sharing this nice module! I have a problem when a word is cut, probably with specific characters.
Any suggestion, please? Thank you!
11 years 8 months ago #1
by Fouli
Hi, can you try to open file /modules/mod_minifrontpage/helper.php with your favorite PHP editor , arround line 372 you will see this code :change that to
11 years 8 months ago #2
$html = mb_substr($html, strlen($matches[0]));$html = mb_substr($html, strlen(utf8_decode($matches[0])));Please Log in or Create an account to join the conversation.
Thanks for the quick reply. This is already in helper.php!
$result .= $matches[1];
//$html = mb_substr($html, strlen($matches[0]));
11 years 8 months ago #3
by Fouli
what about to change this code (at line 445):with this onecan you try it?
11 years 8 months ago #4
$strip = mb_substr($strip, 0, $limit);$strip = mb_substr($strip, 1, $limit, 'UTF-8');Please Log in or Create an account to join the conversation.
I tried, but nothing.
While I have $strip = mb_substr($strip, 1, $limit, 'UTF-8'); ,
If I remove the slashes from the $html = mb_substr($html, strlen($matches[0]));
and put in $html = mb_substr($html, strlen(utf8_decode($matches[0])));
then everything works fine with greek characters but I lose the [...]
11 years 8 months ago #5
by Fouli
- Posted by VC (1) Offline
I have the same problem.
This is already in helper.php [ $html = mb_substr($html, strlen(utf8_decode($matches[0]))); ]
If I change this code:
with this one
The problem now appears in another item.
Can you help me?
10 years 11 months ago #6
by VC
$strip = mb_substr($strip, 0, $limit);with this one
$strip = mb_substr($strip, 1, $limit, 'UTF-8');The problem now appears in another item.
Can you help me?
