quickportfolio - center images
i've just bought your extension. It works but unfortunately the final result is bad. The images are not centered and also they are shown one below the other instead of next to one another (like your demo). How can i display them like your demo site?I don't found any option to do so in the module backend. I used the module for the two images in home and in section called "lista nozze" (you'll find it in main menu).
Thanks.
Regards,
Claudia
11 years 8 months ago #1 by claudia paone
Hi, it's probably because your website loads multiple jQuery. One is loaded by your template and the other one is loaded by the mod_puzzlemania. You can try to install jQuery easy plugin to solve it. extensions.joomla.org/extension/jquery-easy
11 years 8 months ago #2 by TemplatePlazza
okei thanks! i already had the jquery easy plugin installed but it was disabled. now i have enable it and the images are next to one another. However in the home, they are not centered. There is a way to do it?
Regards,
Claudia
11 years 8 months ago #3 by claudia paone
you can stop try to solve my problem because i can't use the jquery easy plugin: when i enabled it, the last menu item doesn't show the submenu items :( i already had this problem with another extension and i'm not able to solve this conflict, so I have to give up using this extension. Thanks anyway for your quick response.
11 years 8 months ago #4 by claudia paone
