minik2 not displaying
- Posted by dibben (5) Offline
I had minik2 working nicely, then after changing some configuration the module disappeared. The content was still visible when inspecting it however nothing was showing. I suspected maybe i had done something wrong so i unistalled it and re-installed latest version (in case there was a bug) now i cannot find the module in the backend. I have tried to manually remove the files via FTP and re-install but still cannot see minik2 module in the backend. Any ideas? Thanks!
Alex
11 years 8 months ago #1
by dibben
Alex
Hi Alex, are you sure you have installed the correct version? there are 2 versions available in the file package, one for j 2.5 and the other one is for j 3
11 years 8 months ago #2
Yes I checked this and i am sure it was the right one, it said the install was successful, but i still cannot see it in the back end.
Alex
11 years 8 months ago #3
by dibben
Alex
strange, can you check whether the problem occur only when you install minik2 or with other module too?
11 years 8 months ago #4
Hey, it looks like just with minik2, i installed your JBounce module and this is showing just fine in the backend. Kind regards
11 years 8 months ago #5
by dibben
Hi, I have entered your administrator page and found that it's the J 2.5 version of mini k2 is installed on your website. I have uninstalled it and installed the j 3.x one and it's displayed on your module manager. Please check.
11 years 8 months ago #6
