PagePeel not working on my site
- Posted by Babatunde Daramola (2) Offline
I use chrome browser and installed joomla 3.X
After installation, page peel does not work.
What should I do?
11 years 8 months ago #1
What should I do?
hi, i'm unable to access your website, are you sure the url is correct?
11 years 8 months ago #2
sorry the url was appended with wrong characters. It has been corrected. the site is www.globalwomenambassadors.com
all other identities are correct. Thanks and waiting in good anticipation of quick fixes.
11 years 8 months ago #3
Hi, the website still unavailable. please see www.dropbox.com/s/2hfmitberirx0qs/nqos5.jpg?dl=0
11 years 8 months ago #4
- Posted by Raj Bambrah (1) Offline
I'm having the same issue - doesn't work for Joomla 3.4.3
website: www.nntrends.com
11 years 2 months ago #5
by Raj Bambrah
Hi RBambrah,
Can you try to switch the template to default one to check whether this is a template problem or something else?
11 years 2 months ago #6
