Latest News Extended on home page opens article below module, need to open to article only like in demo
I have the LNE module on my homepage above content position. When you click on an article it opens below the module where you don't see it unless you scroll down. I want it to open to that article. I've tried adding target="_blank" to the module override but not working. I want it to work like the demo.
11 years 7 months ago #1 by teripratt
Hi, sorry for delay in rsponding.
I think it's because of known joomla itemid issue.
When an article has no menu item, and therefore no itemid, Joomla assigns a default value of 1. For almost all sites Itemid=1 is the frontpage, so when you click the minifrontpage items, the item is actually loaded in your frontpage, but in your case, your template hiding the component section on the frontpage.
It can besolved by creating a new hidden "category" menu item for the article category
11 years 7 months ago #2 by TemplatePlazza
