Joomla 3.4.0
Has there been any issues with Carousel Bannerr and J 3.4.0?
The slider was working perfectly and I am not exactly sure of the time that it stopped being displayed on my site, but I believe it occurred about the same time as the J 3.4.0 release.
It is known that this J release has affected quite a few extensions and plugins. The fix seems to be simple for the developers when it is brought to their attention that their plug in/extension is not working, as they have it fixed very shortly.
Can you please verify that Carousel Banner works in 3.4.0 without any errors?
Thanks.
11 years 7 months ago #1 by cyberspyder
Hi, I have re-tested it, and yes, Carousel Banner works properly with Joomla 3.4.
Please see this : www.dropbox.com/s/yof6ror524isq8r/cbner.mp4?dl=0
11 years 7 months ago #2 by TemplatePlazza
I checked it out again. I uninstalled the module, re-downloaded it from you and re-installed it.
It is displaying now, sort of.
Two issues: (1) The banners never change. It stays on the same number that I choose to display, even though the animatin speed is set to 1,000 (1 second(
(2) When switching to fleisel on alternative layout, so the banners slide, nothing shows on the page.
Can you verify that flexisel works for you, as that is the primary objective that I need, and used before?
Also, do you have any idea why there would not be any animation?
Thanks.
11 years 7 months ago #3 by cyberspyder
Yes flexisel working good too. Please see www.dropbox.com/s/j48x906050rgbpl/crbnn.mp4?dl=0. Btw, it's probably your template. Please let me know your website url so I can check what exactly the problem
11 years 7 months ago #4 by TemplatePlazza
Interesting. Like I said, it was working. I usually use JoomlaXTC templates and extensions, if possible. We had an issue when we were using JXTC NewsPro, that particular module was loading out of position and then popping into its location. Their support said it was a jquery issue with carousel and suggested we disable it. When we disabled carousel,NewsPro worked exactly as it should. I then enabled carousel and they both worked properly. Then J3.3.0 was released which broke NewsPro. JXTC fixed their product with an update. Again, everything worked until a dew days ago when I was working on the site background. Sometime during that few minutes, carousel stopped. That is the background up until my first submission. I am using Ocular template from JXTC currently at www.Tri-StateSpeedway.com. I have carousel set to display in the banner position, but is currently disabled, as I can not get it to function. I have a suspicion that the issue is again with jquery. I have changed different options in both their module and carousel without success.
11 years 7 months ago #5 by cyberspyder
Should have said J3.4.0 was released.
11 years 7 months ago #6 by cyberspyder
