Socio box help
- Posted by Brenda Lloyd (3) Offline
When you click the socio Follow Us on Social Media panel the logos show up but text does as well. How can I remove the text labels.
Thanks in advance.
Brenda
11 years 7 months ago #1
by Brenda Lloyd
Thanks in advance.
Brenda
Hi brenda, I tried to visit your website and entering the credentials you gave but it doesn't work
11 years 7 months ago #2
I put in a second request with the correct login information.
Sorry for the mix up.
Thanks in advance for all your help.
Brenda
11 years 7 months ago #3
by Brenda Lloyd
Brenda
Hmm the css is overrided by your template or extensions you have.
Try to add this code to any of your css file :
11 years 7 months ago #4
.itemewrp span {text-indent: 100%!important;white-space: nowrap!important;
overflow: hidden!important;}Please Log in or Create an account to join the conversation.
That did, thank you very much!
You guys rock!
Will give a great review on the Joomla.org
Brenda
11 years 7 months ago #5
by Brenda Lloyd
You guys rock!
Brenda
