Problem with Responsive Banner Slider
- Posted by Raúl Ramón (14) Offline
I have a jquery problem in my web www.marioelectrodomesticos.com with your module.
Now the jquery are deactivate but not works. Fail
I need that you help me. I need that you connect to me but i have that you send your ip to me to deactivate my security in my hosting. i have a firewall
I need your news
11 years 7 months ago #1
by Raúl Ramón
I need your news
Hi mknofier, Can you try to install this plugin? It's usually works properly for any jquery confliction problem. extensions.joomla.org/extension/jquery-easy
11 years 7 months ago #2
Dear support. This plugin has installed last year. but if i install your module not works.Nothing occurs. JQUERY PROBLEM
i try the configuration jquery in your module but not works.
11 years 7 months ago #3
by Raúl Ramón
Hi, I tried to acccess the your administrator page but it's forbidden.
Btw when I viewed html source of your website, I found that the script that is required to load the slide is not loaded (it's www.marioelectrodomesticos.com/modules/m...er-all.jquery.min.js)
Maybe it's removed by jquery easy plugin. Can you add that script to ignored script list in the jquery easy backend?
( www.dropbox.com/s/r13xvbnjmpgjuhz/vsmtp.jpg?dl=0 )
11 years 7 months ago #4
I add this but your suggestion not works for me...
Can you give me your ip and you can access to my administration joomla
thanks
11 years 7 months ago #5
by Raúl Ramón
thanks
Can you tell me what value did you add to that field? Is it like this? : /modules/mod_responsivebannerslider/assets/adaptor/box-slider-all.jquery.min.js
11 years 7 months ago #6
