How I can change module position Page Peel ?
- Posted by Marie Willemsen (4) Offline
Hello, can I change or choose a (module) position with Page Peel, for example position 0 in joomla template protostar? So Not only on upper right corner?
11 years 5 months ago #1
by Marie Willemsen
Hi, the module indeed forced to be displayed in the upper right corner but you can try to add "position;relative;" to position 0 module wrapper
11 years 5 months ago #2
No it's in ../templates/protostar/css/template.css
try to add this code at the end of file :
11 years 5 months ago #4
.header-search {position:relative!important;}Please Log in or Create an account to join the conversation.
Hi Admin, thanks for your answer. The code doesn't fix the problem with 'Page-Peel' but by using the paid version of 'corners banners' the banner appears in right corner / module 0 in template protostar. Best Regards, Marie.
11 years 5 months ago #5
by Marie Willemsen
Hi Marie, Ah... I didn't realize that there is a paid version of the module
I don't know what the code inside but the both modules seems identical though.
Please let me know your website url so I can check the problem directly
11 years 5 months ago #6
