Problem with Responsive mode in Responsive Banner
What´s happen if i need that the module not works in responsive mode. For example if i need that the module has ever the same size? It´s possible his configuration?
You can see the image that i add
11 years 7 months ago #1 by Raúl Ramón
Hi mknofler, The responsive mode can't be disabled via administrator page, but it can be disabled by modifying some codes in the css file. Please let me know your website url so I can suggest what to change
11 years 7 months ago #2 by TemplatePlazza
11 years 7 months ago #3 by Raúl Ramón
Hi, sorry I just checked the code and unfortunately the height and weight of images are calculated from the given number in the backend (not by css).
I'm not sure whether this will solve your issue but you can try this workaround :
Please open this file with your php editor www.lahuertaencasa.com.es/modules/mod_re...sivebannerslider.php
arround line 65 you will see this code
$sliderHight768 = ($sliderHight/4) * 3;
	$sliderHight360 = $sliderHight768/2;
try to change it to
	$sliderHight360 = $sliderHight768;
11 years 7 months ago #4 by TemplatePlazza
