Problem with countdown module
- Posted by Lorenzo Rossini (11) Offline
since i migrated the site from my computer (local) to the remote server I've several problems.
First problem: the circles have all the same colors and the progress countdown stops working.
test-scorrendo.scorrendoconilliri.it/
I think there is a js conflict... quick.as/VrLGcq2kY
For your information this problem has appeared since I upgraded the module (1.0.1 -> 1.02).
Version 1.01 on my local server does not have this problem.
Second problem: each time I make a change in the module and I save it, one hour is added to the selected time.
quick.as/5ZAJI51qv
Thank you for your support...
11 years 7 months ago #1
by Lorenzo Rossini
quick.as/5ZAJI51qv
11 years 7 months ago #2
can you try to switch the template to default one to check whether the template cause the problem or other extensionsFirst problem: the circles have all the same colors and the progress countdown stops working.
...no, effectively with Beez template activated the problem disappeared.
How is it possible that in local (but with a previous version of countdown module) the problem is not present?
11 years 7 months ago #3
by Lorenzo Rossini
Hmm strange, the only difference between 1.0.1 and 1.0.2 is only one line in the xml file.
Btw, is it the local version identically with the live one?
11 years 7 months ago #4
... yes, exactly the same... I'll try to install version 1.0.1 on remote server to see what happens...
11 years 7 months ago #5
by Lorenzo Rossini
... no, it's the same
so the problem is when the website is migrated on remote server ...
In local -> quick.as/6pwOFQyVv
11 years 7 months ago #6
by Lorenzo Rossini
