MiniFrontPage two time
- Posted by atcweb (3) Offline
Hi, can I use mini frontpage twice to show two different categories. For example dance news and other news page gymnastics. Thanks
11 years 6 months ago #1
by atcweb
You mean to publish two module in one page? Yes it should be ok. Have you try it?
11 years 6 months ago #2
Yes actually published three modules in various articles called from menu. Two minifrontpage work now, the first called by {loadmodule minifrontpage} the second module with {module [153]} so this works. But to call the third minifrontpage article does not work with both codes. How can I fix this? How often can I publish the minifrontpage module at the same time! Thanks
I see this error first:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 19008 bytes) in /usr/home/lsw_data_ws_dro/algemeenswift64/www.swift64.com/www/testswiftweb/modules/mod_minifrontpage/helper.php on line 304
Now I see this error
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 4169 bytes) in /usr/home/lsw_data_ws_dro/algemeenswift64/www.swift64.com/www/testswiftweb/plugins/content/emailcloak/emailcloak.php on line 101
11 years 6 months ago #3
by atcweb
Sorry supplement: the first called by {loadmodule minifrontpage} the second with {module [153]} 153 are id module minifrontpage.
11 years 6 months ago #4
by atcweb
Hi, it probably because of memory_limit setting of your php. Please try one of suggested solutions here : www.itoctopus.com/allowed-memory-size-of...sted-error-on-joomla
11 years 6 months ago #5
