Responsive Banner Slider issues
I have 3 of these modules on the same page and I can't figure out why the banners don't slide along with the Title/alternative text in the Nivo Slider type. It's like the text changes before the image does which just looks weird. I don't think it's because there are three modules on the same page because this was happening to me yesterday before I even added the other two...
Adam
11 years 6 months ago #1 by Adam Melcher
The page these are on is the frontpage.
11 years 6 months ago #2 by Adam Melcher
Hi amelcher, I see that your website loads multiple jquery libs which is probably cause the issue. Can you try to install this plugin extensions.joomla.org/extension/jquery-easy ?
11 years 6 months ago #3 by TemplatePlazza
I already have it installed... not sure how to configure it correctly though...
11 years 6 months ago #4 by Adam Melcher
Hi amelcher,
You just need to enable the plugin and set the 'jQuery' option selected. Pleasee see thi screenshot www.dropbox.com/s/x9lowq62665fxlu/1kh9m.jpg?dl=0
11 years 6 months ago #5 by TemplatePlazza
So it appears that this module is also loading another jquery library that is conflicting with multiple other modules on the page. The site is already loading jquery and doesn't need it loaded again. How can I stop the module from loading jquery and jquery ui?
Adam
11 years 6 months ago #6 by Adam Melcher
