menu2panel slideout not staying in place
- Posted by Steve Donnison (8) Offline
hi, i think I know what you'll say, i can get one menu to slide out correctly offcanvas, but if I copy the panel module and try to add a different menu to that second copy, that is, trying to offcanvas two menu's, it doesn't work.
are we saying you can only present a single joomla menu on the panel2slideout, on mobile?
i have set it up properly!
11 years 6 months ago #1
by Steve Donnison
I'm sorry but I don't really understand what you mean. If you're trying to install two menu2panel module in the same page, then the answer is, yes, you can install only one module per page.
Please let me know if I can be of any further help
11 years 6 months ago #2
ok, i can only use one panel2 module,
so that one module can only display one of the joomla menu's, to explain to anyone else thats dealing with this situation.
thanks
a new menu for mobile phone has to be made, with all the links one needs.
that mobile menu needs to be hidden for desktop if necessary.
11 years 6 months ago #3
by Steve Donnison
thanks
