How to place relatd article under a single document
  • Posted by Erik Schollenberger (1) Offline
Hello Sirs,
please explaine how to configure your extension to have it like this: demo.templateplazza.com/joomla/index.php/default-variation
Kind regards
Erik
11 years 5 months ago #1 by Erik Schollenberger
Hi erick,
You can simply publish the module in a position under the content body. Or alternatively you can call the module from inside the article by using loadposition plugin.
11 years 5 months ago #2 by TemplatePlazza
