Module in Modal directing out of the box !
- Posted by Eduardo (7) Offline
Hello !
Purchased the product " Module in Modal " used in this site: goo.gl/lR4Tsd
If you click outside the box is redirected to the home .
How can I block this?
* Sorry for bad english !
Thank you !
11 years 5 months ago #1
by Eduardo
Thank you !
Hi edufjv, my apologies for delay in responding to your request.
In regards to your problem, did you make any change to the code so it has a dark overlay layer behind the modal?
Additionally, does the same problem exist when you switch the template into the default joomla template (protostar)? I want to check whether this is a template problem or something else
11 years 5 months ago #2
Hello ! Thanks for the answer.
I did not change the code.
The When I put the module on another page than the initial, it works perfectly .
It will be a conflict ?
Thank you.
11 years 5 months ago #3
by Eduardo
Thank you.
Strange, the module should not load any additional overlay layer behind the modal.I did not change the code.
Yes I think so because your web page loads a quite a lot javascript. Can you point me to the page where the module works correctly co I can compare it with your homepage?The When I put the module on another page than the initial, it works perfectly .
Hello , From what I understand , the "logo module" in conflicts .
On this page , removed the module ... Works perfectly , check out:
goo.gl/CraQth
Can you give me a solution?
Thank you!
11 years 5 months ago #5
by Eduardo
goo.gl/CraQth
Thank you!
Hi visited the url you gave but it only shows a black page.
Anyway, can you tell me what logo module did you mean? Is it a custom html module you created from joomla backend or a standalone module you download it somewhere?
11 years 5 months ago #6
