Banners are offset in column display
All banners are being offset by at least 10px to the right using Nivo theme. It cuts off the right hand side of the banner.
11 years 5 months ago #1 by CW Beeler
Hi, It looks like your template gives extra margin to any of image that is placed inside any module block. Please try to add this code to your css file to fix it :
#responsive-banner-slider img {
margin:0!important;}
11 years 5 months ago #2 by TemplatePlazza
I've removed all block margins and padding already. I tried your suggestion and code but no change.
I finally changed the Nivo theme from Bar to Light and that fixed the problem. Thank you though for your help.
11 years 5 months ago #3 by CW Beeler
