Xtypo and very long article issue
using XTypo on a J! 3.4.1 site, very long articles (around 25 pages of printed text) don't work. I get blank content with this error:
Warning: preg_replace(): Compilation failed: regular expression is too large at offset 90492 in /var/www/vhosts/vorrei.org/httpdocs/plugins/content/xtypo/xtypo.php on line 118
disabling XTypo it works fine
How can I fix it?
11 years 5 months ago #1 by theant
HI theant, sorry for delay in responding due to weekend offline.
Regarding your problem it probably because the the long content you have make joomla reaches the PHP regular expression limit you have on your server. Can you try to modify the file /plugins/content/xtypo/xtypo.php and add this code on the top of page (after the opening <?php tag ) so it will become :
<?php
ini_set("pcre.backtrack_limit", "150000");
ini_set("pcre.recursion_limit", "150000");
 * XTypo: Plugin for Content
 * @version		$Id: xtypo.php 2.1
Once it is modified, clear your cache and reopen your website.
11 years 5 months ago #2 by TemplatePlazza
Warning: preg_replace(): Compilation failed: regular expression is too large at offset 89832 in /var/www/vhosts/vorrei.org/httpdocs/plugins/content/xtypo/xtypo.php on line 120
11 years 5 months ago #3 by theant
HI, Can you let me know the URL of your site so I can take a look?
11 years 5 months ago #4 by TemplatePlazza
Yes, but that article is unpublished due the issue:
www.vorrei.org/
11 years 5 months ago #5 by theant
Ah I see, so the error affected to one article only?
11 years 5 months ago #6 by TemplatePlazza
