Responsive banner - adapter slider does not work
Using Joomla 3.4.1 is not working autoplay with type adapter slider.
It does not work also type "sequence" Style 1 and Style 2.
Url example newhistoric.rallyduevalli.it.
greetings
Alessandro
11 years 5 months ago #1 by alejoomla
Hi alejoomla,
I don't the module ublished on newhistoric.rallyduevalli.it. Also, can you try to switch the template into the default one, to check whether it's a template problem or something else?
11 years 5 months ago #2 by TemplatePlazza
hi,
the module is published as you can see from screeshot.
Thank you
11 years 5 months ago #3 by alejoomla
Hi alejoomla,
I think there's a conflict between responsive banner slider with other extension you have on the 'Home' page.
I have setup a page with default template on you deme website with only responsive banner slider installed there (newhistoric.rallyduevalli.it/index.php/test) and it looks it works properly.
Can you try to assign all extensions you have on the Home page one by one to the test page, so we can see what extension is caused the conflict?
11 years 5 months ago #4 by TemplatePlazza
SOLVED
hi ,
the problem is the JB Library Plugin. Thank you for your help.
Alessandro
11 years 5 months ago #5 by alejoomla
Ah ok, thanks for the confirmation Alessandro. Glad it's finally resolved;)
11 years 5 months ago #6 by TemplatePlazza
