Module in popup
Hi when i try 2 module on the same page don´t working. Is possible load 2 or more position on the same page? Thanks.
11 years 5 months ago #1 by Hertak
Hi hertak, unfortunately it is not possible at the moment. It is intended to load only one modal in one page. Sorry about that
11 years 5 months ago #2 by TemplatePlazza
Thanks, will be great feature can load 2 or more. I have a popup on enter and i like use on scroll load to
I
11 years 5 months ago #3 by Hertak
Hmm it will create potential code problems with css and javascript actually. But we'll have alook on it
11 years 5 months ago #4 by TemplatePlazza
I don´t remember wich module is but in configuration you need put a javascript instance name if you don´t put it you have conflict but if you put you can load several instances on same page.
I think the modue is ck menu but i don´t remember well
11 years 5 months ago #5 by Hertak
