Related item Extended module issue
on our site we use your module, it works just fine using Tags:
www.vorrei.org/rubriche/brianzolitudine/...menthal-a-monza.html
but in a new category not:
www.vorrei.org/persone/lab-redazione-mon...to-con-la-sposa.html
into setting “Select Category” is empty because we want to use it in all categores.
Can you help me to understand why it doesn't work anf fix it?
It's a J! 3.4.1 site-
Package 1.0.1
Module 1.4
Plugin 1.0
11 years 5 months ago #1 by theant
Hi, is there any particular extension you have enabled for this page :
Because I found a javascript error on that page :
www.dropbox.com/s/whh85ht6t73bczu/9jbgn.jpg?dl=0
That is not exist on the page :
11 years 5 months ago #2 by TemplatePlazza
Thanks for reply.
Do you see the error in other pages like this?
www.vorrei.org/persone/lab-redazione-mon...re-le-frontiere.html
11 years 5 months ago #3 by theant
Hi theant,
Yes, the error exists on that page too :
www.dropbox.com/s/bfaje68jiujqye9/2m9ec.jpg?dl=0
11 years 5 months ago #4 by TemplatePlazza
Anyway, no. No plugins on that page that is not used in others.
11 years 5 months ago #5 by theant
Hm, can you try to disable plugin plg_jchoptimize and let me know the result? It's the plugin that call the jscss.php
www.dropbox.com/s/e6v3a4t2o3dwe9a/dw3q0.jpg?dl=0
11 years 5 months ago #6 by TemplatePlazza
