SocioBox is Hiding my Main Menu
- Posted by Giovanni Ciavarelli (26) Offline
Hello!
I am setting up a new website and I am doing some tests.
I found out that since I have activated SocioBox, my MAIN MENU sub menus, will go UNDER the module that is under It.
When SocioBox is activated is like my Menu goes into a "Second Layer" hiding under the rest of the page .... You can see It on my website URL.
If you test my Main menu Activating and Deactivating SocioBox you will find the differences!
Sorry I am not able to explain myself in english!
Any Idea?
Thanks!
11 years 4 months ago #1
Any Idea?
Thanks!
P.s.
If I will resolve my problem ... (as I relly need that main menu) ... will It be possible to have SocioBox item Stick in the bottom of the screen? ... Or I'll need to scroll my website? Thanks Again!
11 years 4 months ago #2
Hi clavani,
Can you try to add this code to your css file :
11 years 4 months ago #3
#sp-menu-wrapper {
z-index:999!important;
position:relative!important;}Hmm it should be stick on the bottom of screen, can you try to change the module position of the sociobox into other position (for example 'debug' position)?will It be possible to have SocioBox item Stick in the bottom of the screen?
Hey! Thanks!
It worked! I just added the code in tel menu.less file and now It is not hiding under!
For the second question (a minor question) ... unfortunately I don't have a "Debug" position in my template. SocioButton is staying where i placed It (left in my case, or elsewhere I tried) but I have to scroll down to see It.
Anyway ... My most important problem is solved!
11 years 4 months ago #4
Ah glad it works
Regarding the module position, how about to place it under the same position of credit card logos (in the bottom right)?
11 years 4 months ago #5
I don't need those credit cards so I Just tried
Unfortunately is too on the bottom! So users would have to scroll all site down, that's why I was asking for a way to stick SocioButton on the screen. Maybe It's my template fault! If It's not possible don't worry!
11 years 4 months ago #6
