SocioBox Language ?
- Posted by Giovanni Ciavarelli (26) Offline
Hi again! I know I am a pain in the ass ...
Is there a way to set SocioBox to IT_it ?
I did not find any language reference into module file! :-\
Sorry!
11 years 4 months ago #1
Sorry!
Hi ciavanni,
Socio box uses the standard joomla language method, so to make a italian translation to the module you just need to copy this file nuovo.impavidapallavolo.it/language/en-G...-GB.mod_sociobox.ini , translate it and then and rename it to
nuovo.impavidapallavolo.it/language/it-IT/it-IT.mod_sociobox.ini
11 years 4 months ago #2
I really like SocioBox!
I found my issue!!
I changed It from en_EN to it_IT and I'm done!
Thanks for your support! (of course now I also have language ini file!!!)
11 years 4 months ago #3
I found my issue!!
... locale=it_IT&colorscheme=lightI changed It from en_EN to it_IT and I'm done!
Ah ok, glad you got it solved
Anyway, if you don't mind, could you help us rating the module here :
extensions.joomla.org/extensions/extensi...cial-share/socio-box
It will help us much! Thanks
11 years 4 months ago #4
