Related Items Extended Not Showing
Hi there;
I've had a play around with the Related Items extension.
I haven't got it to display at all on any of my pages. I've tried a combination of settings:
I've tried using both tags and metadata to call the articles
I've tried different layouts (default + slider)
I've tried combinations of jQuery settings in the plugin
I've tried different module positions, as well as directly calling the module within an article using a modules anywhere plugin
I've tried different templates
Not once have I been able to get the related articles extended module to display
Your help in sorting this out would be amazing!
Cheers
11 years 4 months ago #1 by Daniel
Hi fitability,
Strange ..
Btw are you sure have published the module ? Because when I open one of your blog item :
www.fitability.com.au/blog/20-5-golden-rules then view the html source, none of related items extended assets are called (for example, the css file located here www.fitability.com.au/modules/mod_relate...assets/css/style.css)
11 years 4 months ago #2 by TemplatePlazza
I was still playing around with a few options myself so it might not have been published when you had a look.
I figured out that the problem was that a fair few of my articles had no value for their "created date" which resulted in a really odd date in the back-end, despite having a current published year. Obviously this was conflicting with the option to call on articles X amount of days old!
I've now got the module up and running perfectly!
Thanks heaps for your reply though, impressed with how prompt it was!
11 years 4 months ago #3 by Daniel
Ah ok. No problem, glad it's solved ;)
11 years 4 months ago #4 by TemplatePlazza
