Page Peel banner - two peels?
  • Posted by Carole Bartholomew (2) Offline
Hi love your free extension - thank you!!
My peel looks like it has two peels and I don't know what I have done to cause that - can you please have a look at it and let me know
www.echidnawalkabout.com.au/privacy
thanks Caz
11 years 4 months ago #1 by Carole Bartholomew
Hi, strange. Can you temporarily try to switch the template to the default one to check whether this is a tempate problem or something else?
11 years 4 months ago #2 by TemplatePlazza
Thank you for your reply and sorry I could not get back straight away.
I cannot switch to default template as it is not there and at the moment I need to update joomla etc first.
I am working on my localhost offline on plenty of changes and upgrades and with Joomla 3.4.2 it is behaving even less well. It looks like it is there sometimes and then not.
So I will finish what I am doing with this and when it is live I will get back to you if it is not working properly. Again my thanks for your support - I appreciate it.
Caz:)
11 years 4 months ago #3 by Carole Bartholomew
Sure :) No problem
11 years 4 months ago #4 by TemplatePlazza
