Xtypo incl. Button is not working on some sites of my website :(
I have bought and installed your Xtypo extension and buttons and it looks very fantastic on my website holidaypineapple.de!!
Unfortunately it does not work with some of my sites. There is a 3rd party booking extension, which I have added as menu item. For that sites the button does not appear on screen. Instead there is only the regular text link without the xtypo button.
The not working website are: (Temporarily I have added a screenshot of the button)
- www.holidaypineapple.de/florida-ferienvi...on-holiday-pineapple
- www.holidaypineapple.de/neueste-inserate...enhaeuser-in-florida
- www.holidaypineapple.de/login
- www.holidaypineapple.de/kostenlos-registrieren
- www.holidaypineapple.de/kontakt
I would appreciate if you could fix this issue in your extension, because I’m willing to use more buttons on my website. 
Thank you in avance!
Kind regards
Marc
11 years 4 months ago #1 by Marc Pohl
Hi Marcrix, Xtypo is a Joomla content plugin so it works with joomla article only, but if you use xtypo button you probably will be able to use it by calling xtypo css from your template code. You can try to add this code to your <head> section of your template
<link rel="stylesheet" href="/plugins/content/xtypo/themes/default/style.css" type="text/css">
11 years 4 months ago #2 by TemplatePlazza
Thank you!! Now it is working! :D
Kind regards
11 years 4 months ago #3 by Marc Pohl
Hello again,
now after trying to edit a text in the jce editor, it is not possible to set a font color anymore. (e.g. white)
The html code is awlays overwritten, after saving the text.
How can I avoid this error?
Kind regards
11 years 4 months ago #4 by Marc Pohl
Hmm does the issue persist when xtypo button disabled?
11 years 4 months ago #5 by TemplatePlazza
