Mini K2 for K2 Userpage and Items in Category
Hey,
Is it possible to modify the K2 code that the Mini K2 "simple" module is the layout for the K2 Userpage and Category Item list?
Nik
13 years 10 months ago #1 by Nik
Hello Nik
What you could do is to copy the layout and styles of Mini K2 simple layout to both userpage and category item list layout by overriding their component view layout inside your template html folder.
That's what we can suggest to you.
13 years 10 months ago #2 by erwinschro
thanks for your quick reply. can you tell me the folder/document where I have to insert the Mini K2 code.
and what code of the Mini K2 module?
13 years 10 months ago #3 by Nik
Nik,
I'm so sorry if i can't tell you....that would need times and efforts to get done which I don't have.
13 years 10 months ago #4 by erwinschro
no problem I will try it my own
13 years 10 months ago #5 by Nik
I can't solve the problem, maybe someone who can help?
13 years 10 months ago #6 by Nik
