Problem banner carousel width
- Posted by alk (3) Offline
Hi, i have same problems when i try to insert in the width box 990px. You can see the problem at lnx.feelrouge.tv/index.php at the end of tha page. You can see that the system creates a 990px box but show a 720px image. The module functions perfectly in the other part of the site.
Thanls
11 years 3 months ago #1
by alk
Thanls
Hi, can you tell me what is the Banner Width value you entered in the module backend?
11 years 3 months ago #2
Hi, the value is 990px but after some tests, i discover that the problem is in my template. When i tried to insert the module in top template position, it run correctly. Probably, the module has some problems with the position under the sidebar, i use artisteer to create template.
11 years 3 months ago #3
by alk
I see. Anyway, instead of using '990px' how about to use '990' only? Does it work?
11 years 3 months ago #4
