Responsive Banner Slider for IE
- Posted by Paul (6) Offline
Has there been any change in the status of the Responsive Banner Slider for use in IE browsers? Mine will NOT work in IE at all but works fine in FireFox. However I have many users who have only IE. So unless you have found a solution to this problem I am going to have to abandon it.
hpshaiti
11 years 3 months ago #1
by Paul
hpshaiti
Hi singledecker, are you referring to the adaptor effect type ? (because the module should work properly with IE except the adaptor effect type). If so, unfortunately there's still no workaround for old IE browsers as still there is no native support for css3 preserve-3d ( IE starting to support this at their newest Edge browser). Sorry about that.
11 years 3 months ago #2
OK Thanks. Unfortunately most of my folks would have older IE browsers. Yes I was referring to the adaptor as I really like that effect.
11 years 3 months ago #3
by Paul
Hi Shingledecker, I think I have a workaround for this subject. I will add a fallback for IE browsers to have a fadeout effect instead of ugly image slideshow. Will release the update soon.
11 years 2 months ago #4
Hi Shingledecker, I have uploaded the version 3.0. Please redownload and reinstall it and let me know how it works for you. Thanks
11 years 2 months ago #5
