Carousel settings
Dear Sir,
Thank you for your great product! I'm a noob with websites and just helping the local sportsclub. I have some questions and hope you can help me. The carousel is running on the frontpage at the bottom.
    We have >30 banners. Some of then are not shown. What can cause that? If I set the exact number of banners multiple rows are shown.
    Is it possible to put some whitespace between the banners?
    Is it to vertically center the banners?
    Is it possible to set the same background color as the website?
Best regards, Joost
11 years 1 month ago #1 by Joost
can you let me know your module settings in the backend?
yes you can, please add this code to your css file
.nbs-flexisel-item {margin:0 4px!important;}
There is no easy way for that at the moment, I'd recommend you to resize all of your banners for easier and non code based solution
Yes it's possible, add this code to your css file
.nbs-flexisel-inner {
background:none!important;}
11 years 1 month ago #2 by TemplatePlazza
I guess I my response was not in the right place? :)
11 years 1 month ago #3 by Joost
Hi genjozef, yes sorry, I missed your comment because I won't receive notification for comment.
Regarding your problem, I tried to replicate your settings at my end but I'm unable to replicate your problem. Please see this video : www.dropbox.com/s/gshntibgm5rkv1j/caroubaner.mp4?dl=0
The only difference with your settings is all of my banners having the same image size. Maybe you can try to resize all of banners so they have the same size?
11 years 4 weeks ago #4 by TemplatePlazza
No problem at all admin! I'm really very glad with your support!
Thanks for the video. I'll try to set all of the banners to the same image size.
11 years 4 weeks ago #5 by Joost
All the banners have the same size now. That is width 200px and height 150px.
I modified the settings
count 15 to 42
banner widht 468 to 200
banner height 50 to 150
It appears to show all banners now but in 2 rows?
11 years 4 weeks ago #6 by Joost
