Conflict .Js
- Posted by Đinh Văn Quyêt (4) Offline
Dear TemplatePlazza,
I use "Responsive Slider Banner" and one custom module as attachments "top menu.htm"
demo.vied.vn/topmenu.htm
Error "Responsive Slider Banner" can not run.
Please help me.
Thanks in advance Premium
11 years 2 months ago #1
by Đinh Văn Quyêt
Please help me.
Hi, I have a look at your website and found that your website loads multiple jquery libs. Please try to use this plugin to solve it extensions.joomla.org/extension/jquery-easy
11 years 2 months ago #2
Thanks,
I installed "jQuery Easy" but the issue has not been resolved.
Please help me in the account I sent!
11 years 2 months ago #3
by Đinh Văn Quyêt
Hi, I have checked it and found that the plugin is unable to remove one jquery that loads from custom module called : Quảng cáo chạy Bên phải (you manually entered jquery call in the top of this module code). I removed that code and change some jQuery easy configurations and looks like the module is working good now.
Please have a look
11 years 2 months ago #4
Please have a look
Thank you, I've seen.
But my question is: why both "Responsive Slider Banner" and "Quảng cáo chạy Bên phải" not run together.
I want both of "Responsive Slider Banner" and "Quảng cáo chạy Bên phải" to run together.
"Quảng cáo chạy Bên phải" is My "Floating Navigation Menu" Module
11 years 2 months ago #5
by Đinh Văn Quyêt
The floating menu navigation script you're entered uses $ sign as a shortcut for jQuery that is likely will conflict with other script, especially when your environtment is joomla. I have modified your code (I changed $ signs to jQuery) and your floating menu should be working together with responsive banner slider now.
11 years 2 months ago #6
