MiniK2 Filters Not Displaying
I've installed the MiniK2 module for Joomla 3 on my Joomla 3 site and I've selected several categories to display in the module. The images are displaying, but the "Filter by" text is not. All images are showing and there is no option to filter. The filter bar simply displays: <div id="filter"></div> in Firebug.
How can I generate the filter options to show?
Thank you!
11 years 2 months ago #1 by Jessica Paris
Hi, Can you let me know the URL of your site so I can take a look?
11 years 2 months ago #2 by TemplatePlazza
Hi - Unfortunately this is an internal intranet site that you won't be able to gain access to. I unzipped the extension and installed the version for Joomla 3. Created a new module and configured it on the page, selecting more than one category, assuming that that would generate the filter menu. I selected "portfolio" as the theme. Is there another area of the module that needs to be selected to turn on the menu or should it populate automatically based on K2 categories?
Thank you!
11 years 2 months ago #3 by Jessica Paris
Hi, I just re-tested the module and unfortunately unable to replicate your problem. Please see this www.dropbox.com/s/wsfhdvzkihgf4bp/minik2.mp4?raw=1
Can you try to switch your template to default one (protostar) to see whethere this is a template related problem or something else?
11 years 2 months ago #4 by TemplatePlazza
