Carousel animation
- Posted by alk (3) Offline
Hi, is it possible to change animation type? i prefer a simple transition effect and not the standard effect.
11 years 1 month ago #1
by alk
Hi, unfortunately, as its name suggest it provides carousel animation only, it doesn't provide the transition effect.
11 years 1 month ago #2
- Posted by Peter (1) Offline
I love the module, but this "bounce effect" during carousel aimation is very annoying. Any way to easily switch that off?
Many thanks
pp
11 years 1 month ago #3
by Peter
Many thanks
pp
Hi, try to open file [root]/modules/mod_carousel_banner.php, around lines 136 you will see this code :try to change that toor
11 years 1 month ago #4
easing: \'BounceEaseOut\',easing: \'swing\',easing: \'linear\',Please Log in or Create an account to join the conversation.
