Fonticons installation with Gantry 5 Template
I'm experimenting with the new Gantry 5 from Rockettheme. The problem I have is that there is no folder called CSS in the templates which work with Gantry, The structure is a bit different and they use scss for a lot of stuff. I tried adding the custom.css file under the folder templates/templatename/custom/scss but that doesn't work.
Can you tell me where to place this folder?
I can't give you access as I'm doing this on my localhost machine.
Thanks.
11 years 1 month ago #1 by David Jakob
Hi, I'm not familiar with gantry too, but can you try to create 'css' folder inside the [root]/templates/template_name/ folder then put the fonticons editor.css there?
11 years 1 month ago #2 by TemplatePlazza
Thanks - you're suggestion works. Looks good!
David
11 years 1 month ago #3 by David Jakob
Nice! Glad it helps
11 years 1 month ago #4 by TemplatePlazza
