Read more articles button for mini K2
- Posted by vlad (4) Offline
Can you please provide code to add read more articles button in mini K2?
For example, let it load 20 articles and when someone presses read more articles, it shows the next 20 and so on.
Something similar to load more on this extension.
demo.quirkyfoxlabs.com/extn/#joo_pinboardlite4k2
If not, how about scroll reveal?
For a site with large number of articles, it is not feasible to use it.
11 years 1 month ago #1
by vlad
Hi, unfortunately it's not that easy to add ajax / infinite scroll implementation to the module. It will require a quite alot code changes and probably will be better to be done in the component / plugin level. Sorry about that.
11 years 1 month ago #2
Yes, that the one I said about adding ajax. It's better to do that from template override side as module capability is somewhat limited
11 years 4 weeks ago #4
Can you give a hint or point in the right direction on how to do it from template override? I am using latest version of Joomla 3.4.
api.joomla.org/cms-3/classes/JPagination.html
Can we have a module class to do this for any module?
stackoverflow.com/questions/12725306/pag...tom-module-in-joomla
11 years 3 weeks ago #5
by vlad
Maybe you can start from here www.google.co.id/webhp?hl=en#hl=en&q=infinite+scroll+joomla+k2
11 years 3 weeks ago #6
