Xtypo button not showing in JCE 2.5.6
- Posted by Franck Diagou (3) Offline
Xtypo button does not show in my editor. I follow all the steps you mentionned in the documentation but it still does not show.
Need a quick help.
10 years 9 months ago #1
by Franck Diagou
Need a quick help.
- Posted by TemplatePlazza (5456) Offline
Hi, I have entered your website and when I tried to open the JCE editor, I found the buttons under the wysyg editor is not appeared on your website (such as page break button, images , read more etc) like this one on my backend
How did you hide it?
10 years 9 months ago #2
Also, I see you use the outdated version of Joomla and jce. Is it possible for you to update them to the latest version?
10 years 9 months ago #3
I think there's a problem with your JCE installation. When I tried to change the default editor to TinyMCE, those joomla editor buttons are displayed properly (including the xtypo button).
I think you should try to update your JCE version to the latest one.
10 years 9 months ago #4
I do not have the possibility to update joomla, otherwise a lot of my modules, plugins, extensions no longer work!
JCE won't let me ugrade the installation with the current joomla version I have.
Please help
10 years 9 months ago #5
by Franck Diagou
Please help
Hi, I understand with the situation.
Updating Joomla is very risky when you have many components/extensions are installed.
It looks like I will not be able to help you fix it, because the JCE issue affecting the basic function of joomla editor button and there's nothing we can do because you can't update it.
I'd suggest you to ask JCE developer to find solution for this issue, or you can switch to TinyMCE if you still want to use xtypo button (because it works good with TinyMCE wehn I tested it) or if you want to uninstall it and no longer use Xtypo you can email us your Paypal transaction ID at www.templateplazza.com/contact-us to get a refund.
10 years 9 months ago #6
