Z-index Module in modal
  • Posted by Ton van der Helm (67) Offline
on www.vollebregtbrommobiel.nl/aixam-store-nederland I'm using the button "OKTOBER ACTIE!" to trigger the Module in Modal.
But as you can see the images of the small slideshow are on top of the Module in Modal. I've tried to change the z-index of this by adding to the custom css:
#jbounce-jmodal {
z-index:99999999;}
But unfortunately without luck.
How can I fix this?
Thanks!
11 years 3 weeks ago #1 by Ton van der Helm
Hi try to add this code to your css file :
.mimodal
 z-index:999!important;
11 years 3 weeks ago #2 by TemplatePlazza
Thanks! This works :-)
11 years 3 weeks ago #3 by Ton van der Helm
Nice! Glad it helps ;)
11 years 3 weeks ago #4 by TemplatePlazza
