Popup Greyed out
Hi Installed the ,odule but the pop up is grey out and unusable, guess its css but thats the extent of my guessing. Any thoughts?
thanks in advance, joe. Rockettgheme extension, with hikashop. Joomla 3
www.jourdanonline.net/site/index.php/contact-us
11 years 3 weeks ago #1 by Joe
Can you try to publish it in other module positions, to see the issue related only to the module position or with the template globally?
11 years 3 weeks ago #2 by TemplatePlazza
thanks moved it "breadcrumb" same issue...
11 years 3 weeks ago #3 by Joe
can you try temporarily to switch the template to the default joomla template protostar, to check whether it's indeed a template problem or maybe an issue with extensions you have?
11 years 3 weeks ago #4 by TemplatePlazza
Works fine in Protostar, looks like the template, Rocket Theme Chimera thanks joe
11 years 3 weeks ago #5 by Joe
can you try to add this code to your css file :
#fade {
z-index:99!important;}
11 years 3 weeks ago #6 by TemplatePlazza
