Popup doesn't appear
- Posted by werk26 (2) Offline
Hello!
For an Joomla 1.5.26 site I need to use your Popup-Extension www.joomlaos.de/option,com_remository/It...ileinfo/id,4430.html
I published the module, but the pop-up doesn't appear. www.hugo-lauf.de/newsletter.html
Can you help?
11 years 2 weeks ago #1
by werk26
Can you help?
Hi, we're actually no longer support Joomla 1.5 nor the module, but I have tried to enter your website and try published the module to see what I can help.
I found that the problem is because the module needs the mootool.js (old joomla default javascript lib) to be included in the template, but it looks like your template doesn't load it.
11 years 2 weeks ago #2
Thank you for your support! We found another solution for popup on this site right now... Thanks and have a nice day!
11 years 2 weeks ago #3
by werk26
