Promo Space close after a few seconds
Hello, congratulate the module works perfectly , but wanted advice if you may be close after a few seconds.
Thanks for listening , greetings .
11 years 1 week ago #1 by Joao
HI, open the file ../modules/mod_tppromospace/assets/script.js, change this code :
jQuery('#button-close').live('click', function(){
		jQuery('#tppromospace' ).animate( { opacity: '0' }, { queue: false, duration: 750 });
		jQuery('#tppromospace').delay(500).slideUp(400);
		jQuery.cookie('tppromospace', '1');
		jQuery('#button-close').hide();
		jQuery('#button-show').show();
to
setTimeout( function(){
}  , 2000 );
11 years 1 week ago #2 by TemplatePlazza
Thanks , works almost perfect, has a bug that does not close the window if you open it , any ideas ?
11 years 1 week ago #3 by Joao
Ah, ok. Then re-add the code after the new code, so the code will look like this :
}  , 2000 );
11 years 1 week ago #4 by TemplatePlazza
Ayoma Hello, you solved your problem? I tried but I can not obtain the claimed effect. If you have solved, could you pass the list of files script.js changed?
Thank you
10 years 10 months ago #5 by mariano
