Jbounce won´t work
Hey, I installed Jbounce on Joomla 3.4. activated the module, typed in some text in header etc. and enabled the Dev. Mode but nothing is coming up, any Ideas?
And some question too, do i have to choose an position, since its only for modal? I tried it both ways anyway, no luck :/
10 years 11 months ago #1 by Ariel Atsamo
Can you let me know the URL of your site so I can take a look?
Yes, you have to, to make the code is called from your frontend
10 years 11 months ago #2 by TemplatePlazza
Sure - umzugshelfer.website/sixt
Its placed in the Footer.
10 years 11 months ago #3 by Ariel Atsamo
can you try to disable plugin jchoptize and see what happen?
10 years 11 months ago #4 by TemplatePlazza
