Pell banner no corner
I've lost the graphic bottom corner on my peel banner with Firefox (it was working at the beginning, some days ago)
I've just have a squarre with a piece of my banner visible but no more the graphic corner style at the bottom of the module
the module works
I see the same on your demo page
is it a problem with my Firefox config or upgrade ?
It works well with Safari
but the module is not displayed at all with Chrome
thanks
10 years 10 months ago #1 by Gedge
Hi I'm unable to open your website, it said the webpage is not available.
I tried to open the demo page with firefox and chrome and both of them working good
https://www.dropbox.com/s/jet5p4ntj3lnerv/6geon.jpg?raw=1
https://www.dropbox.com/s/vvkwtqng060hsf6/40glx.jpg?raw=1
10 years 10 months ago #2 by TemplatePlazza
sorry I forgot the .fr to my website url
I corrected that on the post edit
Would you please take a look and maybe tell me what's wrong with my website ?
Thanks for the support
10 years 10 months ago #3 by Gedge
It looks like the page peel css is overrided by your template css.
Try to add this code to your css file :
#page-peel-banner {
position:relative!important;
position:fixed!important;
z-index:999999!important;}
10 years 10 months ago #4 by TemplatePlazza
I think you made a mistake ? two positions (relative - fixed..)
I deleted position relative to enable position fixed only
that fixed the problem under Chrome but I still don't have the graphic corner under Firefox
can you see the complete design on my website using Firefox ?
see attached what I see
(it's ok under Chrome)
10 years 10 months ago #5 by Gedge
Ups sorry,
Yes you can delete the position:relative part
Anyway
Your website looks good when opened with firefox. Please see :
i.imgur.com/NxuXlef.png
Have you tried to clear your browser caches?
10 years 10 months ago #6 by TemplatePlazza
