Countdowns only visible for Super Users
- Posted by Sascha Zeisler (5) Offline
Hi there,
when I setup a countdown module on a site which is only reachable through a login, the countdown is only visible for Super Users. Should be visible for every registered user.
The module rights are set correctly.
Must be a problem with the module.
Any idea?
10 years 11 months ago #1
by Sascha Zeisler
Any idea?
Hi, It should be nothing related to the module code but can you let me know the URL of your site so I can take a look?
10 years 11 months ago #2
Sure:
www.it-event.info
Where can I send the login data to you?
The error only occurs on sites, which need a frontend login.
10 years 11 months ago #3
by Sascha Zeisler
www.it-event.info
You can enter the details using the "You Site Details" tab below. Only support team who are able to see that.Where can I send the login data to you?
Additionally the module looks working good from here. Please see www.dropbox.com/s/62cfm5cfbwjot35/fra6k.mp4?dl=0
Am I missed something?
10 years 11 months ago #5
Okay, I have added the information.
In the extra info, you see an account with registered right only. With your admin account, you will see the counter after the login.
With the test user, it's gone.
10 years 11 months ago #6
by Sascha Zeisler
