Problem with application CK
- Posted by Geoffroy (4) Offline
I use Slideshow of CK (www.joomlack.fr/extensions-joomla/slideshow-ck) and Maximenu of CK (www.joomlack.fr/extensions-joomla/maximenu-ck).
When I installed and brought online mod_latestnewsplusxtd_j30, the two aforementioned programs no longer work at all.
There is a compatibility issue with this range of interesting modules.
How can I solve my problem because I like what is in place.
Have you got a update for my problem?
Thank and best regards
10 years 11 months ago #1
by Geoffroy
Hi I opened your website but unable to see the problem (maybe you disabled the module).
Anyway, the problem sounds like a jquery confliction to me. Can you try to use this plugin? : extensions.joomla.org/extension/jquery-easy
It usually solve most of jquery confliction issue
10 years 11 months ago #3
I have actived latestnews and JQuery-Easy.
Now you see my module "menu CK" and "slideshow CK" has bug
10 years 11 months ago #4
by Geoffroy
Hi, It's really strange because latest news module doesn't involve any javascript script call (the module doesn't have any javascript file).
Anyway, after doing some tests I found that the conflict is actually not between the module and the CK modules but with the component droppic you have installed.
When the module is enabled, the droppics component strangely call its libraries (css, and javascript) partially so that causes javascript error.
You can see on this page www.topsniper.ch/web/index.php/news/ligu...emaison-ca-bosse-dur
Both of modules (latest news xtd and CK modules) are working properly.
Please have a look on this www.dropbox.com/s/913ecp9fq1945q6/95svm.jpg?raw=1 , on that page the nivo script is calling without calling the necessary lib www.topsniper.ch/web/plugins/droppics/ca....nivo.slider.pack.js .
While on this page : www.topsniper.ch/web/index.php/news/ligu...emaison-ca-bosse-dur both of scripts are called.
I'm still investigating this issue, in the meanwhile if you have any information about this droppics component please let me know.
10 years 11 months ago #5
I think I found what cause the issue. The latest news module by default loads content plugin, including the droppics content plugin. The droppics plugin calls nivo slider javascripts, but not all necessary javascripts are called. The main nivo javascript (/jquery.nivo.slider.pack.js) seems only be loaded in the article page/view, when a slideshow added to the article.
I edited the file ../modules/mod_latestnewsxtd/tmpl/default.php and added a manual call for file jquery.nivo.slider.pack.js and looks like it fixes the problem. Please check
10 years 11 months ago #6
