Jbounce background
- Posted by Francesco (4) Offline
Hi, thanks for your free extension Jbounce. It works fine. Only one question: can you suggest me a way to avoid to see some backgrounds modules? Please see this example www.taichionline.it/news.html or if you prefer the attachment jpg. Some modulew are stiill visible (no opacity) and create some confusion. Thank you. Best regards
Francesco
10 years 11 months ago #1
by Francesco
Francesco
Can you try to add this code to your css file?
10 years 11 months ago #2
.bottomcolumn1 {
position:relative!important;
Thank you for the fast support!
Unfortunatly the css code doesn' work.
The strange thing is that facebook comment extension and the items menu on the right column have their background white (100% opacity). The items menu on the left column have the correct opacity and look grey.
Thank you
Francesco
10 years 11 months ago #3
by Francesco
Thank you
Francesco
Ok, please remove the current code and use this one :
10 years 11 months ago #4
#jbounce-jmodal {
z-index:9999!important}Please Log in or Create an account to join the conversation.
Fantastic! It works well.
Today I will leave a very good review about your extension, thank you
Francesco
10 years 11 months ago #5
by Francesco
Francesco
Nice. Glad could help. And thanks for the review. Realy appreciate it
10 years 11 months ago #6
