Possible to hide the "no flash installed" message on "not flash compatible" devices?
- Posted by Ove Heradstveit (2) Offline
Hi!
Thank you very much for the great extension with the Page Peel-banners. It's working perfect. My question is therefore not on an error / issue, but is just a custom configuration question.
More specifically, I just wonder if there is any way to hide the "no flash installed" message which appears at devices which do not have flash installed (such as Iphone). Is this possible to achieve with a custom hack within one of the files of the extension? If so, which file?
Thank you very much for your response in advance!
10 years 11 months ago #1
by Ove Heradstveit
Hi, the warning comes from the browser, so we have no control for that. How about using the jquery version?
10 years 11 months ago #2
Thank you for your response. Yes, than I will stick to the jquery Version. It is working fine, so that's no problem
10 years 11 months ago #3
by Ove Heradstveit
