Responsive Banner Slider overlap
Hi I bought from you module "Responsive Banner Slider" and install in to Joomla 3.4. I have problem when I duplicated module with the same effect, I't overlap.
Best regards,
Alex
10 years 5 months ago #1 by Aleksandar Keta
  • Posted by TemplatePlazza (5444) Offline
Hi can you temporarly switch the template to the default one (protostar) to check whether this is related to template or something else?
10 years 5 months ago #2 by TemplatePlazza
Hi I was check. On protostar template it look fine
10 years 5 months ago #3 by Aleksandar Keta
Can you try to add this code to your template css and tell me whether the problem persists or not:
#responsive-banner-slider {
    display: block!important;
10 years 5 months ago #4 by TemplatePlazza
I was added code but still nothing
10 years 5 months ago #5 by Aleksandar Keta
Can you help me? For 5 days I don't get any answer from you. I put banner on different location and I got same owerlap reult
10 years 5 months ago #6 by Aleksandar Keta
